Highlighted
Re: Recent IAP Firmware Releases
Instant 4.0.0.4 (6.3.1.2-4.0.0.4) Released Feb. 24, 2014
This is a minor release with one enhancement and several bug fixes. Release highlights are listed below.  Check the Release Notes for a complete list of new features.
Enhancements:
  • IAP-225 now supports up to 128 ACLs for an SSID or wired profile through the CLI.
Bug Fixes:
  • Access Points – two AP crash related issues.
  • Aruba Central – Fixed issue where an IAP-175 could not connect to Central.
  • Auth – erroneous error msg displayed “Authentication Server is Down”.
  • Firewall- “show datapath user” displayed incorrect user details.
  • L2TPv3 – multiple connectivity related issues
  • RTLS – Communication issue to RTLS server.
  • Security –medium level vulnerabilities found in cipher suite.
  • STM – Some clients not able to associate to IAP-225 with Client-Match and background Spectrum monitoring enabled.
  • Virtual Controller – IAP-225 rebooted due to VC transition from one IAP to another.
Highlighted
 Enhancements:
  • Configurable Port for Communication between IAP and AirWave Management Platform.
  • Command Outputs generated from the Support Window in a Single Page
  • GUI Enhancements for Air Monitor Configuration
Bug Fixes:
  • AirGroup – random connectivity issues to connected AppleTV’s
  • AirWave – (1) An IAP stopped communicating with AirWave and was marked as Down in the AirWaveUI, although the IAP functioned locally. (2) When the Airwave IP address, shared key, and organization configuration details were applied to an IAP from the AirWave management system, the AirWave IP details were not displayed in the CLI.
  • AP Platform – (1) The Bandwidth graphs did not display any data due to the AP clock corruption. (2) The IAP-22x devices kept sending multicast traffic even though no wireless client was connected to the IAP.
  • Authentication - Some Apple devices could not authenticate
  • Captive Portal - The HTTP 408 error was displayed when the users tried to connect to the external captive portal through Port 80.
  • Datapath - An IAP rebooted randomly when the CLI process opened too many files.
  • IAP Provisioning - The system log of an IAP displayed the error message, APAS provision failed, code: failprov-no-rule….
  • Instant UI - The Continue login link in the Login page was not correctly displayed when the Instant UI was launched from an unsupported browser
  • SNMP- When an SNMP GET operation was performed for the aiClientUptime object (OID-1.3.6.1.4.1.14823.2.3.3.1.2.4.1.16), no output was received.
  • Vlan Configuration - The allowed VLAN configuration settings on Virtual Controller were not replicated on slave IAPs in a cluster.
  • WiFi Driver - GE Dash devices were not able to access devices on the network when connected an IAP on a WPA-PSK-TKIP SSID
Highlighted
Instant 4.0.0.6 (6.3.1.4-4.0.0.6) Released June 9, 2014
Enhancements:
  • Support for Fully Qualified Domain Name (FQDN) Lookup.
Bug Fixes:
  • Management  – IAP-105 was unable to come up on Aruba Central without a valid NTP configuration
  • Authentication – When the RADIUS server was down clients were prompted multiple times.
  • General – Executing clear-cert server command did not delete the uploaded server cert.
  • Palo Alto Server – When connecting via 802.1x the MAC address of the client was displayed rather than the username.
  • STM – DHCP timeout alerts were generated even after an IP address was delivered to the client.
  • User Interface – Users were unable to rename an IAP from the GUI.
  • WiFi Driver –Clients were unable to receive ARP broadcast from the IAP.
Highlighted
Instant 4.1.0.0 (6.4.0.2-4.1.0.0) Released June 10, 2014
This is a Major release with many new and exciting features!  The release highlights are below.  Be sure to download a copy of the Release Notes for complete details and the 4.1 Users Guide for a complete description of each feature.
  • AppRF:
AppRF on Instant comprises two components - On-board DPI (on newer AP platforms) and cloud-based web policy enforcement (on all AP platforms except the IAP-9x).DPI identifies individual, well-known applications (list of ~1500, same as AOS) and allows network administrators to enforce a variety of policy actions on a per-user, per-application basis. DPI is supported on IAPs 103, 114/115, 224/225, 274/275. On supported platforms, DPI is part of InstantOS and requires no add-ons.
For Web-enforcement, InstantOS leverages Webroot’s Brightcloud database - a cloud-hosted database which inspects millions of websites in real-time and classifies them by functional category and reputation.
Using this information InstantOS can again enforce a variety of policy actions.
Unlike other vendors who offer one or the other, combining both engines into a single enforcement engines allows networks to have a simple, flexible framework that combine applications, functional categories and security.
And AppRF on Instant continues to have the advantages of the distributed-forwarding, virtual-controller architecture in terms of survivability and scaling.
NOTE: The Web Enforcement component requires a per-AP, annual subscription to the cloud service. The Web-Enforcement subscription can obviate the need for a dedicated Web / URL filtering engine for the deployment. Details of the SKUs (Aruba product & updated June price-list), purchasing and enforcement will be provided soon.
  • Platforms:
Instant 4.1 will support new AP models - the IAP-103, IAP-274 and IAP-275.
IAP-92/93 is NOT SUPPORTED in Instant 4.1.0.0. IAP-92/93 will be supported in Instant 4.1.0.1 for the rest of the 4.1 release cycle, but with some features disabled - likely including AirGroup, SNMP, internal 802.1x, EAP Termination, WiFi uplink etc. A complete list will be included in the release documentation. IAP-92/93 customers requiring these features should stay on. Instant 4.1 is the LAST SUPPORTED RELEASE for the IAP-92/93.
  • AirGroup Enhancements:
Instant 4.1 extends the AirGroup umbrella to include DLNA and support Android / ChromeOS environments as well.
  • Zones:
Instant 4.1 includes a long awaited feature of advertising specific SSIDs (say, guest SSID) only on a subset of APs in the cluster (say the lobby APs).
  • Authentication Survivability:
Instant 4.1 extends the existing authentication survivability capability for EAP-PEAP to include EAP-TLS as well. This feature will be supported with non-Aruba AAA servers also, and will be key to BYOD deployments.
…and many more features - details of which can be found in release documentation.
As always, the 4.1 release will be available on the Aruba support site for now, and will be uploaded to the cloud firmware server soon.
Highlighted
Instant 4.0.0.7(6.3.1.8-4.0.0.7) Released July 8, 2014
 Enhancements:
  • Support for Mexico country code
Bug Fixes:
  • Authentication – Accounting stop packet caused client to re-authenticate.
  • AirWave (2) – Connectivity issue from VC to AirWave and Users showing incorrect role “instant” in AirWave.
  • Captive Portal – space in filename of custom captive portal logo caused cluster instability
  • CLI – IAPs randomly rebooting
  • Datapath / Firewall – Kernel crash during L3 Roaming
  • General – Cannot send Gratuitous ARP after a Slave VC became Master VC
  • RAP-NG – L3 clients unable to reach VPN destination after IAP failover to WiFi uplink
  • VPN – IAPs unable to communicate with Syslog server using the inner IP
Highlighted
Instant 4.1.0.1 (6.4.0.3-4.1.0.1) Released July 30, 2014
This is a minor release with two enhancements and several bug fixes. Release highlights are listed below.  Check the Release Notes for a complete list of new features.
Enhancements:
  • Regulatory Domain updates
  •  Reintroduced IAP-9x into the 4.1.x.x code base.       Limitations do apply – check the Release Notes for details.
Bug Fixes:
  • AirWave – IAP still broadcasting “Instant” SSID after receiving config from AirWave.
  • Authentication – 4 Radius issues
  • Captive Portal – Cluster instability after loading a custom Captive Portal logo.
  • Datapath – (1) Lync voice and video not properly prioritized when using the “Classify Media” firewall option. (2) IAP-135 crash under load.
  • RAPNG – IAP unable to send Syslog messages when VPN connectivity enabled.
  • STM – IAP reported incorrect OS type for Blackberry Z10.
  • VPN – IAP register message did not reach controller.
  • Wireless – (1) Broadcast packets dropped causing loss of connectivity on IAP-225 under heavy load.    (2) IAP crash due to Watchdog timeout
Highlighted
Instant 4.1.0.2 (6.4.0.3-4.1.0.2) Released Sept. 4, 2014
This is a minor release with only bug fixes. Release highlights are listed below.  Check the Release Notes for a complete list of new features.
Bug Fixes:
  • AirGroup – AirGroup was unable to maintain a record of cache servers.
  • Authentication – Clients were unable to connect to slave IAPs when the WPA-passphrase contained a “space”.
  • ARM – (1) Voice issues when a SIP phone was connected to IAP-22x. (2) Poor 2.4Ghz performance for legacy traffic.
  • DHCP – Exclude IP address range was not taking effect.
  • UI – IAP user session remained connected after password was changed.
  • VC Management – (1) Warning message “CLI module is running in a degraded state. Some commands will not function” when trying to connect to the CLI when the external RADIUS server was unavailable. (2) IAP-105 unable to re-join a cluster after a SW upgrade due to a specific MAC address range not being recognized.
  • VPN – Motorola scanners were taking too long to join the network.
 Release Notes and SW can be downloaded here:
         Instant 4.1.0.3 Release Notes and SW
Highlighted
Instant 4.1.1(6.4.2.0-4.1.1.0) Released September 22, 2014
Instant v.4.1.1.0 is a major release with many new features. Release highlights are listed below.  Check the Release Notes for a complete list of new features and fixes.
Platform:
  • IAP-205 / 205 (2x2:2 .11ac)
  • IAP-214 / 215 (3X3:3 .11AC)
AppRF enhancements:
  • Support for IAP to send AppRF data to AirWave 8.0.4.
  • AppRF data aggregation in VC from individual SSIDs across all IAPs.   Previously, AppRF data was only viewed on a per-IAP basis.
ClientMatch enhancements:
  • Previously, ClientMatch looked at received RSSI from client probe requests.   ClientMatch now examines received RSSI of all frames from the client providing more accurate and real-time measurement and improved steering.
Security:
  • Support for separate RADIUS Authentication and Accounting servers.
  • Support for MAC address delimeter and uppercase characters for all authentication types.
Management:
  • Improved troubleshooting capabilities
Highlighted
Instant 4.1.1.1 (6.4.2.0-4.1.1.1) Released November 10, 2014
Instant v.4.1.1.1 is a patch release with two minor enhancements. Release highlights are listed below.  Check the Release Notes for a complete list of new features and fixes.
 Enhancements:
  • New Syslog message. When a new user is added or deleted a NOTICE message with the IP and MAC is sent.
  • Age field in RSSI sent to ALE server.
Fixes:
  • Authentication: (1) When using separate Authentication and Accounting servers the Accounting packets were not being sent.(2) A legacy 802.11b handheld failed to authenticate using dynamic WEP/EAP-TLS.
  • Captive Portal: Did not work with custom certificates.
  • Datapath / Firewall: DHCP forwarding delayed when Captive Portal and MAC Auth were enabled.
  • General: (1) IAPs were rebooting stating that the System Clock was far ahead of the NTP sync result. (2) IAP-22x was unable to perform an LACP failover when Eth0 was down.
  • IDS: False alerts on Rogue APs causing some clients to be flagged as a Rogue.
  • SNMP: (1) SNMPv3 traps with inform enabled were not getting processed on the IAP-204/205. (2) Incorrect output was generated for ESSID with SNMP walk, get, or get-next finctions.
  • STM: Clients using MAC auth and 802.1x auth went into a deny-all role when roaming with PMK cache in the cluster.
  • VPN: A factory reset IAP was unable to bring up an IPSec tunnel when managed by AirWave.
