MVP Guru
Re: Role-based access rules not being applied
@Yan Liu wrote:
We do support role derivation without using an external RADIUS server, but we can only derive based on inherent attributes such mac address, and not RADIUS attributes such as Aruba-Essid-Name.
Also, could I ask why we are trying to derive based on Arub-Essid-Name?  Because it seems redudant as the default role is already per-SSID.  If the goal is to define a different access policy for each SSID, then just setting the policy in the default role (or just using network-based access control), should be enough.
Role derviation is geared toward giving different roles to different clients even if they are on the same SSID.
Yan
I tried that but it didn't worked, it placed the device on the default role too . I have the latest IAP OS installed
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi Victor,
Do you mind pasting the output of running configuration from CLI or from UI's support window so we can see the full config?
Yan
I change the role-based access rules and the external auth radius servers, but the client are connecting to the old role. We use external guest auth.
how can I force the client to associate to the new role?
Please open a new thread.  This post is from 4 years ago.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
