IAP Cluster running 8.6.0.4_74969
When running the speed-test command I'm only getting ~400Mbps no matter which AP I set to master.
Since this is a command running between the AP and a server plugged into the same switch, I would expect ~900Mbps
I tried on my AP365, then swapped the master to a 303H and tested there.
Garage# speed-test 10.0.7.35 tcp
Server listening on 5201
Accepted connection from 10.0.7.55, port 65146
[ 5] local 10.0.7.35 port 5201 connected to 10.0.7.55 port 65147
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 49.9 MBytes 418 Mbits/sec
[ 5] 1.00-2.00 sec 49.0 MBytes 411 Mbits/sec
[ 5] 2.00-3.00 sec 48.6 MBytes 407 Mbits/sec
[ 5] 3.00-4.00 sec 49.5 MBytes 415 Mbits/sec
[ 5] 4.00-5.00 sec 47.0 MBytes 394 Mbits/sec
[ 5] 5.00-6.00 sec 49.2 MBytes 412 Mbits/sec
[ 5] 6.00-7.00 sec 49.7 MBytes 417 Mbits/sec
[ 5] 7.00-8.00 sec 49.5 MBytes 415 Mbits/sec
[ 5] 8.00-9.00 sec 49.8 MBytes 418 Mbits/sec
[ 5] 9.00-10.00 sec 44.3 MBytes 372 Mbits/sec
[ 5] 10.00-10.00 sec 185 KBytes 410 Mbits/sec
[ 5] 0.00-10.00 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.00 sec 487 MBytes 408 Mbits/sec receiver
If I unplug the master AP and test from a laptop using the same cable I get much better results.
Accepted connection from 10.0.7.186, port 62086
[ 5] local 10.0.7.35 port 5201 connected to 10.0.7.186 port 62087
[ 5] 0.00-1.00 sec 102 MBytes 854 Mbits/sec
[ 5] 1.00-2.00 sec 108 MBytes 907 Mbits/sec
[ 5] 2.00-3.00 sec 111 MBytes 931 Mbits/sec
[ 5] 3.00-4.00 sec 111 MBytes 931 Mbits/sec
[ 5] 4.00-5.00 sec 112 MBytes 940 Mbits/sec
[ 5] 5.00-6.00 sec 111 MBytes 930 Mbits/sec
[ 5] 6.00-7.00 sec 111 MBytes 933 Mbits/sec
[ 5] 7.00-8.00 sec 111 MBytes 931 Mbits/sec
[ 5] 8.00-9.00 sec 106 MBytes 893 Mbits/sec
[ 5] 9.00-10.00 sec 111 MBytes 933 Mbits/sec
[ 5] 10.00-10.04 sec 4.39 MBytes 933 Mbits/sec
[ 5] 0.00-10.04 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.04 sec 1.07 GBytes 919 Mbits/sec receiver
Since I believe this is a test of the wired connection I believe my APs are not operating to their full ability.
I also tried with 4 threads and achieved worse results
Garage# speed-test 10.0.7.35 tcp bandwidth 1000 sec-to-measure 20 server-port 5201 parallel 4
Accepted connection from 10.0.7.55, port 65150
[ 5] local 10.0.7.35 port 5201 connected to 10.0.7.55 port 65151
[ 7] local 10.0.7.35 port 5201 connected to 10.0.7.55 port 65152
[ 9] local 10.0.7.35 port 5201 connected to 10.0.7.55 port 65153
[ 11] local 10.0.7.35 port 5201 connected to 10.0.7.55 port 65154
[ 5] 0.00-1.00 sec 9.15 MBytes 76.8 Mbits/sec
[ 7] 0.00-1.00 sec 9.11 MBytes 76.4 Mbits/sec
[ 9] 0.00-1.00 sec 9.10 MBytes 76.3 Mbits/sec
[ 11] 0.00-1.00 sec 9.01 MBytes 75.5 Mbits/sec
[SUM] 0.00-1.00 sec 36.4 MBytes 305 Mbits/sec
[ 5] 1.00-2.00 sec 9.55 MBytes 80.1 Mbits/sec
[ 7] 1.00-2.00 sec 9.53 MBytes 80.0 Mbits/sec
[ 9] 1.00-2.00 sec 9.54 MBytes 80.0 Mbits/sec
[ 11] 1.00-2.00 sec 9.53 MBytes 80.0 Mbits/sec
[SUM] 1.00-2.00 sec 38.1 MBytes 320 Mbits/sec
[ 5] 2.00-3.00 sec 9.45 MBytes 79.3 Mbits/sec
[ 7] 2.00-3.00 sec 9.45 MBytes 79.2 Mbits/sec
[ 9] 2.00-3.00 sec 9.44 MBytes 79.2 Mbits/sec
[ 11] 2.00-3.00 sec 9.44 MBytes 79.2 Mbits/sec
[SUM] 2.00-3.00 sec 37.8 MBytes 317 Mbits/sec
[ 5] 3.00-4.00 sec 9.50 MBytes 79.7 Mbits/sec
[ 7] 3.00-4.00 sec 9.51 MBytes 79.8 Mbits/sec
[ 9] 3.00-4.00 sec 9.50 MBytes 79.7 Mbits/sec
[ 11] 3.00-4.00 sec 9.49 MBytes 79.6 Mbits/sec
[SUM] 3.00-4.00 sec 38.0 MBytes 319 Mbits/sec
[ 5] 4.00-5.00 sec 9.49 MBytes 79.6 Mbits/sec
[ 7] 4.00-5.00 sec 9.49 MBytes 79.6 Mbits/sec
[ 9] 4.00-5.00 sec 9.49 MBytes 79.6 Mbits/sec
[ 11] 4.00-5.00 sec 9.49 MBytes 79.6 Mbits/sec
[SUM] 4.00-5.00 sec 38.0 MBytes 318 Mbits/sec
[ 5] 5.00-6.00 sec 9.27 MBytes 77.8 Mbits/sec
[ 7] 5.00-6.00 sec 9.28 MBytes 77.9 Mbits/sec
[ 9] 5.00-6.00 sec 9.29 MBytes 77.9 Mbits/sec
[ 11] 5.00-6.00 sec 9.29 MBytes 77.9 Mbits/sec
[SUM] 5.00-6.00 sec 37.1 MBytes 311 Mbits/sec
[ 5] 6.00-7.00 sec 8.84 MBytes 74.2 Mbits/sec
[ 7] 6.00-7.00 sec 8.85 MBytes 74.2 Mbits/sec
[ 9] 6.00-7.00 sec 8.85 MBytes 74.3 Mbits/sec
[ 11] 6.00-7.00 sec 8.83 MBytes 74.1 Mbits/sec
[SUM] 6.00-7.00 sec 35.4 MBytes 297 Mbits/sec
[ 5] 7.00-8.00 sec 9.58 MBytes 80.3 Mbits/sec
[ 7] 7.00-8.00 sec 9.57 MBytes 80.3 Mbits/sec
[ 9] 7.00-8.00 sec 9.57 MBytes 80.2 Mbits/sec
[ 11] 7.00-8.00 sec 9.59 MBytes 80.4 Mbits/sec
[SUM] 7.00-8.00 sec 38.3 MBytes 321 Mbits/sec
[ 5] 8.00-9.00 sec 9.07 MBytes 76.1 Mbits/sec
[ 7] 8.00-9.00 sec 9.08 MBytes 76.2 Mbits/sec
[ 9] 8.00-9.00 sec 9.08 MBytes 76.2 Mbits/sec
[ 11] 8.00-9.00 sec 9.08 MBytes 76.2 Mbits/sec
[SUM] 8.00-9.00 sec 36.3 MBytes 305 Mbits/sec
[ 5] 9.00-10.00 sec 9.15 MBytes 76.7 Mbits/sec
[ 7] 9.00-10.00 sec 9.14 MBytes 76.7 Mbits/sec
[ 9] 9.00-10.00 sec 9.14 MBytes 76.7 Mbits/sec
[ 11] 9.00-10.00 sec 9.13 MBytes 76.6 Mbits/sec
[SUM] 9.00-10.00 sec 36.6 MBytes 307 Mbits/sec
[ 5] 10.00-11.00 sec 9.48 MBytes 79.5 Mbits/sec
[ 7] 10.00-11.00 sec 9.47 MBytes 79.4 Mbits/sec
[ 9] 10.00-11.00 sec 9.49 MBytes 79.6 Mbits/sec
[ 11] 10.00-11.00 sec 9.48 MBytes 79.5 Mbits/sec
[SUM] 10.00-11.00 sec 37.9 MBytes 318 Mbits/sec
[ 5] 11.00-12.00 sec 9.49 MBytes 79.5 Mbits/sec
[ 7] 11.00-12.00 sec 9.51 MBytes 79.7 Mbits/sec
[ 9] 11.00-12.00 sec 9.49 MBytes 79.5 Mbits/sec
[ 11] 11.00-12.00 sec 9.48 MBytes 79.5 Mbits/sec
[SUM] 11.00-12.00 sec 38.0 MBytes 318 Mbits/sec
[ 5] 12.00-13.00 sec 9.53 MBytes 80.0 Mbits/sec
[ 7] 12.00-13.00 sec 9.53 MBytes 79.9 Mbits/sec
[ 9] 12.00-13.00 sec 9.53 MBytes 80.0 Mbits/sec
[ 11] 12.00-13.00 sec 9.53 MBytes 79.9 Mbits/sec
[SUM] 12.00-13.00 sec 38.1 MBytes 320 Mbits/sec
[ 5] 13.00-14.00 sec 9.66 MBytes 81.0 Mbits/sec
[ 7] 13.00-14.00 sec 9.67 MBytes 81.1 Mbits/sec
[ 9] 13.00-14.00 sec 9.66 MBytes 81.1 Mbits/sec
[ 11] 13.00-14.00 sec 9.67 MBytes 81.1 Mbits/sec
[SUM] 13.00-14.00 sec 38.7 MBytes 324 Mbits/sec
[ 5] 14.00-15.00 sec 9.51 MBytes 79.7 Mbits/sec
[ 7] 14.00-15.00 sec 9.51 MBytes 79.8 Mbits/sec
[ 9] 14.00-15.00 sec 9.51 MBytes 79.8 Mbits/sec
[ 11] 14.00-15.00 sec 9.50 MBytes 79.7 Mbits/sec
[SUM] 14.00-15.00 sec 38.0 MBytes 319 Mbits/sec
[ 5] 15.00-16.00 sec 9.54 MBytes 80.0 Mbits/sec
[ 7] 15.00-16.00 sec 9.54 MBytes 80.0 Mbits/sec
[ 9] 15.00-16.00 sec 9.53 MBytes 80.0 Mbits/sec
[ 11] 15.00-16.00 sec 9.54 MBytes 80.0 Mbits/sec
[SUM] 15.00-16.00 sec 38.2 MBytes 320 Mbits/sec
[ 5] 16.00-17.00 sec 9.48 MBytes 79.5 Mbits/sec
[ 7] 16.00-17.00 sec 9.48 MBytes 79.4 Mbits/sec
[ 9] 16.00-17.00 sec 9.50 MBytes 79.6 Mbits/sec
[ 11] 16.00-17.00 sec 9.48 MBytes 79.5 Mbits/sec
[SUM] 16.00-17.00 sec 37.9 MBytes 318 Mbits/sec
[ 5] 17.00-18.00 sec 8.30 MBytes 69.7 Mbits/sec
[ 7] 17.00-18.00 sec 8.28 MBytes 69.6 Mbits/sec
[ 9] 17.00-18.00 sec 8.31 MBytes 69.7 Mbits/sec
[ 11] 17.00-18.00 sec 8.28 MBytes 69.5 Mbits/sec
[SUM] 17.00-18.00 sec 33.2 MBytes 278 Mbits/sec
[ 5] 18.00-19.00 sec 8.53 MBytes 71.6 Mbits/sec
[ 7] 18.00-19.00 sec 8.71 MBytes 73.1 Mbits/sec
[ 9] 18.00-19.00 sec 8.72 MBytes 73.1 Mbits/sec
[ 11] 18.00-19.00 sec 8.72 MBytes 73.2 Mbits/sec
[SUM] 18.00-19.00 sec 34.7 MBytes 291 Mbits/sec
[ 5] 19.00-20.00 sec 8.79 MBytes 73.7 Mbits/sec
[ 7] 19.00-20.00 sec 8.78 MBytes 73.6 Mbits/sec
[ 9] 19.00-20.00 sec 8.78 MBytes 73.6 Mbits/sec
[ 11] 19.00-20.00 sec 8.79 MBytes 73.6 Mbits/sec
[SUM] 19.00-20.00 sec 35.1 MBytes 294 Mbits/sec
[ 5] 20.00-20.01 sec 0.00 Bytes 0.00 bits/sec
[ 7] 20.00-20.01 sec 0.00 Bytes 0.00 bits/sec
[ 9] 20.00-20.01 sec 0.00 Bytes 0.00 bits/sec
[ 11] 20.00-20.01 sec 0.00 Bytes 0.00 bits/sec
[SUM] 20.00-20.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 0.00-20.01 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-20.01 sec 185 MBytes 77.7 Mbits/sec receiver
[ 7] 0.00-20.01 sec 0.00 Bytes 0.00 bits/sec sender
[ 7] 0.00-20.01 sec 185 MBytes 77.7 Mbits/sec receiver
[ 9] 0.00-20.01 sec 0.00 Bytes 0.00 bits/sec sender
[ 9] 0.00-20.01 sec 186 MBytes 77.8 Mbits/sec receiver
[ 11] 0.00-20.01 sec 0.00 Bytes 0.00 bits/sec sender
[ 11] 0.00-20.01 sec 185 MBytes 77.7 Mbits/sec receiver
[SUM] 0.00-20.01 sec 0.00 Bytes 0.00 bits/sec sender
[SUM] 0.00-20.01 sec 742 MBytes 311 Mbits/sec receiver
How do I resolve this so my APs get their full throughput?
