Re: Troubleshooting assistance: IPads roaming problem on instant
KP-Niklas is right.
Please change "Broadcast" to ALL for all of your SSIDs.
Also remove 802.11r and 802.11k because a number of clients have issues with them.
Can we have a screenshot of your ARM settings, as well as your dashboard of your AP utilization?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor I
Hi thank you for your responses.
I have attached screenshot of ARM settings
Regards Jens
Regards Jens W
Contributor I
How is your transmit rates under the SSID's ? to get better roaming set the maxumim til 54 and minimum 11, for 2,4 GHz, and 54 as max and min 12 for 5 GHz.
try to roam with the new settings and report back :)
/Niklas
Contributor I
Hi
I have changed them.
I have attached an overview over the AP's
Regards Jens
Regards Jens W
Something is wrong.  You have the minimum of 6 and maximum of 9, but some access points are still outside of that power:
Also, what is your regulatory domain?  I see that there are some DFS channels in use and we need to remove those.  Also, under ARM we need to make sure wide channels is "none" or "disabled"
Contributor I
The regulatory domain is Denmark (DK)
the power levels where adjusted because of the AP's are placed very close to each other.
Hmm I had not seen that the Min and Max TX not where applied.
There is alot of 2,4 radios where it is ignored but all of the 5ghs radios ignores them apperently.
How can that be??
If I understand what you mean with removing all DFS channels correctly I would be stuck with only channels 36, 40, 44, 48 is that correct?
And what about the +channels should I deactivate those to ?
Regards Jens
Regards Jens W
Contributor I
Regards Jens W
What is your regulatory domain?
Contributor I
Denmark = Europe
I have the list of non DFS channels from here
http://en.wikipedia.org/wiki/List_of_WLAN_channels
What is the reason for not using those channels ?
Regards Jens W
I am wrong.  Your channels are fine based on EU
We need to find out why your access points are not paying attention to the power settings.
