Contributor I
Re: Troubleshooting assistance: IPads roaming problem on instant
OK
Yes that is very odd that they ignore the setting.
I have found out though that the 5Ghz radios has channels set manually wich also sets tha TX power manually, so they are alle 20.
The client has set the channels manually because of this discussion on apple.com
https://discussions.apple.com/thread/6601963?start=2025&tstart=0
Do you have any input on this "solution"
*Regards Jens
Regards Jens W
They need to allow the channels and power to be automatic.  The power needs to have a max of 18, otherwise that creates roaming problems.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor I
OK I will inform the client,and make the required changes.
What do I do about those AP's that ignores the 2,4Ghz tx max.
The AP's are set to ARM assigned on the 2,4 radio
Regards Jens
Regards Jens W
Try rebooting one.
Contributor I
I have just checked the AP list again and now all AP's exept one are at its MAX TX of 9.
Would also look like that the MAX is to low since they all use MAX.
But the distance between the AP's is some placeses below 7m with a wall between them.
What should the max be, to be sure that we do not an single AP with alot of power and clientmatch problems.
Regards Jens W
Contributor I
Set the MAX TX to 15 and minimum to 9. Its a good middelway for AP TX power in Schools in Denmark, Bulding materials etc will have an effect on this.
Contributor I
Thank you I will inform my customer and get these changes implemented
Regards Jens W
Contributor I
The changes are made, and the AP's seem to find a TX level of 12 to 15 so the levels seem fine.
The AP util/Noise/errore page under Controller monitoring also looks better now.
I have told the customer to test the roaming the next couple of days, and report back.
Regards Jens W
Contributor I
Hi
The customer has done some testing now, and they still see the problems described in the first post.
IPad simply drop the connection sometimes when roaming, and sometimes need resetting WIFI on the IPad in order to connect again.
Regards Jens
Regards Jens W
Please post the list of the access points again with the power and utilization.
