Contributor II
Tunnel between IAP Clusters
I've recently learned to configure tunnels between IAP clusters and mobility controllers.  Is it possible to acheive something similar between two IAP clusters?  I have a situation where I'm replacing a small (50 AP) campus network and considering using an instant cluster.  They also have 4 or 5 remote sites which are currently running standalone APs.  I will be controlling this all via AirWave, but I'm wondering if it will be possible to tunnel traffic from the remote IAP clusters (cluster of 1) to the central cluster.
Re: Tunnel between IAP Clusters
You cannot.  You would have to have a controller at the central site that all the clusters tunnel to.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor II
Thanks for that info.  I know the underlying OS is capable because this is how layer-3 mobility is acheived so it's too bad they didn't make this feature user configurable.  Oh well, maybe in the future.
