Re: Using Two Certificates SSL in Aruba Instant with Clear Pass Guest
Find out from your SSL decryption vendor how things need to be configured. Like Tcappalli said, it would NOT be on the WLAN controller or the AAA authenticator.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
How can I solve this problem without changing the client's infrastructure?
Is there any solution to this problem or only if I make the firewall auto-sign the certificate?
You need to work with your partner. This conversation has gone wildly off track.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Okay, I'm the partner, thanks for the clarification.
I need to install two certificates of CA but not possible on IAP.
I got just one.
Why would an SSL intercept CA server need to be installed on a Captive Portal?
Why would you be doing SSL intercept on guests?
I need to install two client CA certificates because internal users of the wired network can only access https sites in this way.
They have a certain difficulty in the firewall, because it can not generate a self-signed certificate, so I can not get the visitors and mobile network users to access such https sites without these certificates.
I was able to install only one certificate in the IAP, but it only allows 1 CA certificate. Is there a way to solve this?
Guests will not allow you to install certificates on their machines, so I think you have a fundamental problem that you need to solve.  Unfortunately I don't think it involves IAPs or ClearPass.
