Virtual Controller IP suddenly not reachable, neither direct IPs of IAPs in a IAP215/IAP225 cluster
  • 1.  Virtual Controller IP suddenly not reachable, neither direct IPs of IAPs in a IAP215/IAP225 cluster
    Posted Mar 29, 2020 04:56 PM
    Hi
    as topic describes, simple IAP215/225 cluster which was upgraded from 8.5.0.6 to 8.6.0.2 last week . Today wanted to check webui for somewhat - i dont really remember - but the static virtual controller IP wasnt reachable, no ping , neither single IP's (dhcp both) of the 2 IAP were reachable , normally i enter the virtual IP with http:// and it auto-redirects to the :4343 , same happens when accessing the single IAPs IP adress (you all know by yourselves).
    environment:
    really simple 192.168.0.0/24 network, no vlans, no special config used.
    just hard plugged out both IAPs and et voila virtualcontroller IP again reachable . no client issue with the ping/access as i tested from 3 different clients. from my opinion (never had this) the webUI just stopped responding. im about to upgrade to 8.6.0.3 tomorrow , just wanted to ask the community if someone else experienced this after upgrading to 8.6.0.2
    regards and keep on going, i like this place!
    benjamin
  • 2.  RE: Virtual Controller IP suddenly not reachable, neither direct IPs of IAPs in a IAP215/IAP225 cluster
    Posted Mar 31, 2020 07:59 AM
    Any specific reason to upgrade from 8.5 to 8.6 ?
    When you click on Check Firmware, what does it return (i think it returns 8.3 or 8.4). This is the version you can use.
