Virtual controller IAP cluster
  • 1.  Virtual controller IAP cluster
    Posted Jun 15, 2020 04:53 AM
    Hello, i would like to ask. Can IAP-92 deployed as virtual controller manage AP-387?
    What are the requirements for IAP cluster?
    Thank you
  • 2.  RE: Virtual controller IAP cluster
    MVP EXPERT
    Posted Jun 15, 2020 06:05 AM
    Hi, this would not work due to the age of the APs and firmware requirements.AP-387 requires a minimum firmware of AOS/InstantOS 8.4  An AP-92 will support a maximum of ArubaOS 8.2 or Instant 4.1.
    The AP-387 is a Unified AP so therefore can be managed by Virtual Controller (Instant) mode without the need for an AP-92.
  • 3.  RE: Virtual controller IAP cluster
    Posted Jun 15, 2020 10:15 AM
    IAP-92 won’t be able to manage the 387 since the last supported released on the IAP-92 was Instant 4.1 and the 387 starts at InstantOS 8.4
    https://www.arubanetworks.com/support-services/end-of-life/#AccessPoints
    Sent from Mail for Windows 10
