Have a project where i have below:
Internet --> Firewall --> HP switch --> 3x 375
Haver worked on Aruba before so need help:
1) What are best practices for IAPdeployement
2) I am assuming i will configure Virtual Controller between 3 IAPs, Where should I be configuring DHCP VLAN Pool - I do not have separate DHCP server so i would be using IAP as DHCP server so question is woud the default gateway be the IAP or would it be the Firewall? my FW would normally be playing Default gateway for VLANs but not sure in terms of SSID (VLAN) attachment will the gateway be the IAP or FW VLAN ip
Any suggestions :)
