MVP Expert
Re: WiFi Uplink feature with Instant 8.5
What list are you looking at then? Because the list I found in the manual does not mention 360 or 370 series AP.
Koen (ACMX #351 | ACDX #547 | ACCP)
I think the user guide must have categerised 3XX series that inlcudes all the 37x models as well.
I found that in my testing that I needed to enable enforce uplinke and set it for wi-fi.  Am I doing something wrong?
I am conducting my testing on an AP-303H running 8.5
No I dont think you are doing anything wrong, it is a valid setting. We have the uplink priority list that includes Eth0, WiFi sta and 3G/4G. you can use it based on your use case.
Understood, but my AP won't even try to log into the SSID unless enforce uplink is set... in your testing was that the case?
That depend on your "uplink priority list". Is WiFi-sta the top priority there?
By default WiFi-sta is the second priority uplink and for that to kick in, Eth0 should be disconnected. In my setup, if you refer to the page 5 of the PDF document that I pubished, you'll notice that Enforce uplink = none but WiFi-sta was my top priority uplink.
My priority list was setup exactly as the document specified. Any other ideas on why I need to also set the enforce uplink option?
Sent from my iPad
that should not happen, I used IAP-315 with Instant version 8.5.0.
Are you using IAP-315s? also have you enabled Pre-emption?
here is the extract from the user guide on the expected behavior of "Enforcing uplink"
Hi!
I’m using a 303H in my testing and I have pre-emption toggled on.
Niten
Niten Jaiswal
Senior Solutions Architect
email: jainiten@amazon.com | office: 646-817-7320
[AWS Certified Solutions Architect - Associate]
[AWS Certified SysOps Administrator - Associate]
[AWS Certified Developer - Associate][signature_584266402]
Thoughts on our interaction? Provide feedback here.
Thanks.
Nice work with the document.
I got it running, but it seems depending on the eth0 link, if that is not up when booting the wireless uplink does not come up.
Also, in my particular test with 203R it stops working after having run for a little while.
Did you make any tests with no wired ports, only wireless uplink and wireless clients ?
