Highlighted
Contributor I
aruba IAP/Airwave De-Auth after 1 hour
hello,
we are running IAP clusters and Airwave is managing them (no controller)
our guest network has devices connect for hours sometimes.
is there a way to say after 1 hour deauth? and make them log back in to the CP ?
Highlighted
MVP Guru
Re: aruba IAP/Airwave De-Auth after 1 hour
What is doing the authentication for your CP/Guest Network, is this the internal DB on the IAP or an external source?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
Contributor I
the CP (for this guest SSID) is local to the IAP it does not use our clearpass or anything.
Highlighted
MVP
you can enable "deauth inactive clients", which is under configuration for a specific SSID. this will be visible if you click on "show advanced options"
Also note that the "inactivity timeout" is by default set to 1000 sec. you can change that to suit your env.
If a reply adequately addresses your issue, please click on the "Accept as Solution"
