client suddenly lost connection randomly
This thread has been viewed 116 times
  • 1.  client suddenly lost connection randomly
    Posted Jun 23, 2020 12:04 AM
    Hi all,
    I need some help here.
    Some clients that connect to AP has suddenly disconnected by itself.
    It happened on random devices at random times.
    When i tried to check the log using 'show ap client trail-info' command on devices that disconnected, the log show this info 'wlan driver excessive tx fail quick kickout'.
    Standalone Controller: Aruba 7210 with os version 8.6.0.2
    AP: 305 and 315
    Any ideas what causes these?
  • 2.  RE: client suddenly lost connection randomly
    Posted Jun 23, 2020 03:01 AM
    If you don't get a quick answer, please open a case with Aruba support.
  • 3.  RE: client suddenly lost connection randomly
    Posted Jun 23, 2020 07:28 AM
    @merkusi wrote:
    Hi all,
    AP: 305 and 315
    This has already been observed.  Please open a Technical Support case to get to the bottom of your specific issue.
  • 4.  RE: client suddenly lost connection randomly
    MVP GURU
    Posted Jun 23, 2020 09:15 AM
    If max-tx-fail retries value is reached, then the client will be deauthed from the AP. But like everyone has been saying, I would open a TAC case.
  • 5.  RE: client suddenly lost connection randomly
    Posted Jun 23, 2020 09:31 AM
    To be clear, this is an issue that is known.  Please open a technical support case to see if the fix applies to you or if this message is generated by a situation that is not currently fixed.
  • 6.  RE: client suddenly lost connection randomly
    Posted Jun 26, 2020 12:01 AM
    I’m sorry for my late response.
    I’ve tried many ways in attempt to solved this problem but still no avail.
    I will follow your suggestion to open ticket for this case.
    Thank you very much for the helps and I’m sorry for my bad English
  • 7.  RE: client suddenly lost connection randomly
    Posted Sep 02, 2020 04:57 AM
    Is this issue fixed ? We experience the same with quite a lot of AP-315's (about 1/4 of our installed base) on AOS version 8.6.0.5 currently and having an uptime of around 40 days.
    After an apboot, the issue is gone for a while.
  • 8.  RE: client suddenly lost connection randomly
    Posted Sep 21, 2020 11:44 PM
    we fixed this issue by downgrade the os to version 8.5.0.10
  • 9.  RE: client suddenly lost connection randomly
    Posted Jul 08, 2021 10:04 AM
    This problem was fixed on version 8.7.1.4.
    Wlan driver excessive tx fail quick kickout
    Herbert Ferreira
  • 10.  RE: client suddenly lost connection randomly
    Posted Jun 09, 2021 10:31 AM
    on excessive retries, the AP deauths the client.
    8.6 build onwards, in this case you should see the error :" Wlan driver excessive tx fail quick kickout".
    Previously, you would have seen the error:  "Denied: AP Ageout".
    investigating the excessive retries by doing air captures would be required for further analysis
    Ahmed Farouk
  • 11.  RE: client suddenly lost connection randomly
    Posted Feb 15, 2022 02:21 PM
    We have been experiencing this for some time as well. Rebooting the APs seem to alleviate the symptom for a short period of time. We will be upgrading to 8.7.xx as soon as we get a few AP 100 models off the network and a 8.7 conservative release comes out.  Thank for all the updates....
    Scott Kirkland
  • 12.  RE: client suddenly lost connection randomly
    Posted May 17, 2022 03:41 PM
    Did you get this fixed ? We are seeing these logs "wlan driver excessive tx fail quick kickout" with some users with wifi issues. We are using 8.6.0.17 and in 8.6.0.10 release notes mention that was fixed
    Adriano Pugedo
  • 13.  RE: client suddenly lost connection randomly
    Posted May 17, 2022 04:29 PM
    wlan driver excessive tx fail quick kickout is a general message that means a client roamed out of coverage and the access point still had data to deliver to the client.  It is not specific.  I would open a technical support case to determine your issue.
  • 14.  RE: client suddenly lost connection randomly
    Posted May 17, 2022 05:00 PM
    We are not going to 8.7.x.x but it seems 8.6.0.17 has a lot of fixes for these oddities that our clients have seen. Out of 6000 APs we are 97% 315's. We are planning to upgrade to 8.6.0.17. We have had TAC involved with some of the issues.
    Scott Kirkland
