Highlighted
Contributor I
'commit apply' doesn't work - nothing is changed
i have a problem with changing the configuration of an instant cluster via cli.
The Cluster ist running version 6.5.3.6 (IAP-225).
If i change something in the configuration, i can see the differences with 'show uncommitted-config'.  When i look at the config ids (show aps), as example they are 4 for all aps.
Now i enter 'commit apply' and i see:
committing configuration...
configuration committed.
When i look at the config ids, they increased to 5. So all aps should have the new configuration. But if i take a look at  'show running'....nothing changed.
How can i find out what is going wrong?
If do the changes via WebUi, everything is working fine.
