iap 225 and iap 303
These access points can they work together?. I mean can they share the same network?
MVP Guru
Re: iap 225 and iap 303
As long all IAPs are running Aruba InstantOS 8.3.0.0 or Aruba InstantOS 8.4.0.0 for the 303P. They will form a cluster if in the same L2 broadcast domain. If they are L3 separate they will be in separate clusters.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
