Highlighted
Occasional Contributor I
identify the issue and restart the controller from cli
I just inherited a controllerless set of aruba instant.
Usually I was able to manage them going to this address.
https://10.100.254.50:4343/#home
now that page is no longer available.
So i tried to ping 10.100.254.50 with success.
Then I logged via ssh to 10.100.254.50
Then I issued the following command:
show aps
wich gave me this list:
19 Access Points
Name IP Address Mode Spectrum
AP-KAIZEN 10.100.254.51* access disable
AP-SEZPOST 10.100.254.54 access disable
AP-CEDTECNOCOMM 10.100.254.61 access disable
AP-SQB 10.100.254.56 access disable
AP-PRODACQ 10.100.254.52 access disable
AP-SALACDA 10.100.254.63 access disable
AP-NAUTICA 10.100.254.58 access disable
AP-SPEDIZIONI 10.100.254.60 access disable
AP-VERNICIATURA 10.100.254.64 access disable
AP-STAB-B 10.100.254.66 access disable
AP-ASSEMBLAGGI 10.100.254.65 access disable
AP-APPLICAZBAZ 10.100.254.57 access disable
AP-PRESSAPIANI 10.100.254.59 access disable
AP-MAGAZENTRATA 10.100.254.55 access disable
AP-MENSA 10.100.254.67 access disable
AP-STAB-C 10.100.254.62 access disable
AP-STAB-A2 10.100.254.68 access disable
AP-FINESTABILIMA 10.100.23.29 access disable
AP-FORATRICI 10.100.254.53 access disable
Here is what I want to do: restart the 10.100.254.50 and check if the web user interface becomes available again.
Can you suggest me the proper command?
Highlighted
Re: identify the issue and restart the controller from cli
it seems that reload did it.
