successor or replacement for IAP-207
  • 1.  successor or replacement for IAP-207
    Posted Apr 29, 2020 01:07 PM
    Hello
    In our school we have a mix of IAP-103, IAP-205 and IAP-207 devices. I want to add some more access points. The IAP-207 is not longer for sale.
    What should I buy as alternative? Can I use the AP-303 in my controllerless environment? It is not an 'instant IAP'. I want a device in the same price range as the IAP-207 (200 - 250 euro).
    Thanks.
  • 2.  RE: successor or replacement for IAP-207
    Posted Apr 29, 2020 01:35 PM
    Yes I would go for 303
    https://www.arubanetworks.com/assets/support/EOS_207-Series-Campus-APs.pdf
    The 303 Series access points can be deployed in
    either controller-based (ArubaOS) or controller-less
    (InstantOS) deployment mode.
