Occasional Contributor I
Re: users seeing dropped connections
The only thing I see that is too different is for some reason we enabled
broadcast filtering for ARP only. Not sure if this would have any impact
on you.
If the network dropping is happening frequently, you could drop 2.4 GHz for
a short period to see if the network stabilizes. I understand your issue,
we have 4 devices we have to replace to m ake this work.
*Jim McMurchie* | *Smartsheet*
IT Manager
*d* 425-324-2266
jim.mcmurchie@smartsheet.com
Winner : Best 100 Companies to Work For 2014
www.smartsheet.com
Contributor I
Please change you RF settings:
arm
 wide-bands 5ghz
 min-tx-power 6 -SET TO 12
 max-tx-power 127 - SET TO 15
 band-steering-mode prefer-5ghz
 air-time-fairness-mode fair-access - SET TO Preferred Access
 client-aware
 scanning
See the changes in the RF.
I'll give these changes a shot and let you know how we make out.
I do have one question, for the minimum power, I set it low because each of our rooms has an AP, so there's a fair amount of interference, particlularly on the 2.4GHz band where there are limited channels to use. Is there a way to set the TX power of the different radios/bands to different settings? I wouldn't be opposed to turning off an AP's 2.4GHz radios to have a more coverage-over-capacity model on that band, but keep all the AP's 5Ghz radios on as a capacity-over-coverage model.
Bryan Murphy -- Network Admin
Wellsboro Area School District
Contributor I
Hey,
Don't mind the 2,4 GHz band. It has to be there do not turn it off, you can however use this command in the ARM;
band-steering-mode force-5ghz
this will force all the clients with 5 ghz radios up on the high band, and everyone is happy.
