Data Center
2930f and PPPOE
I've a novice so please excuse my ignorance (I have some background in Linux / LEDE project, though).
I'd like to use Aruba 2930f a little bit like a router. Is it possible to establish PPPOE session for uplink? Can I have two PPPOE sessions (one ipv4 and one ipv6)?
Can I do NAT with it?
Is there any documentation that would cover it?
I'll appreciate your help.
MVP Expert
MVP Expert
Re: 2930f and PPPOE
no, cannot be done.
You can use 2930f as LAN2LAN router but not as WAN router.
Regards, Jörg
Please give kudos, if you like my post.
Please Accept as solution, if my post was helpful.
