Deutschsprachiges Forum
Airwave auf Centos 6.10
Hallo, hat es jemand geschafft Airwave auf einem Centos 6.10 zu installieren? Die aktuelle ISO von Airwave verwendet Centos 6.6. Diese Version erkennt den verbauten Raid Controller (Dell R640) nicht. Unter Centos 6.10 kann der Server installiert werden, die Installation von Airwave wird allerdings mit folgendem Fehler beendet:
ALTER SCHEMA
ERROR: relation "visualrf.user_preference" does not exist
ZEILE 1: SELECT EXISTS(select 1 from visualrf.user_preference where u...
^: SELECT EXISTS(select 1 from visualrf.user_preference where user_name=? and field_name=?) (admin,use_metric_units) at /usr/local/airwave/lib/perl/Mercury/UpdateDB/1510872837.pm line 13
Mercury::UpdateDB::1510872837::action('Mercury::UpdateDB::1510872837') called at /usr/local/airwave/lib/perl/Mercury/UpdateDB/Base.pm line 31
Mercury::UpdateDB::Base::__ANON__() called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 937
Mercury::Utility::ChangeDB::__ANON__() called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 787
Mercury::Utility::ChangeDB::modify_database('CODE(0x164bb6d0)', 'CODE(0x1652b960)') called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 941
Mercury::Utility::ChangeDB::_schema_change('add use_metric_units per user', 'CODE(0x162103c0)') called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 879
Mercury::Utility::ChangeDB::__ANON__() called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 666
eval {...} called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 653
Mercury::DB::Q::_run_then_do('Mercury::DB::Q', 'CODE(0x164a4af0)', 'CODE(0x11527130)') called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 624
Mercury::DB::Q::run_in_transaction('Mercury::DB::Q', 'CODE(0x164a4af0)') called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 880
Mercury::Utility::ChangeDB::schema_change('add use_metric_units per user', 'CODE(0x162103c0)') called at /root/git/mercury/bin/update_db.pl line 112
update_db::__ANON__('Parallel::Forker::Process=HASH(0x11360e28)') called at /opt/airwave/local/lib/perl5/site_perl/5.10.1/Parallel/Forker/Process.pm line 233
Parallel::Forker::Process::run('Parallel::Forker::Process=HASH(0x11360e28)') called at /opt/airwave/local/lib/perl5/site_perl/5.10.1/Parallel/Forker.pm line 153
Parallel::Forker::poll('Mercury::Parallel::Forker=HASH(0x112a4628)') called at /opt/airwave/local/lib/perl5/site_perl/5.10.1/Parallel/Forker.pm line 94
Parallel::Forker::wait_all('Mercury::Parallel::Forker=HASH(0x112a4628)') called at /root/git/mercury/bin/update_db.pl line 211
update_db::go('update_db') called at /root/git/mercury/bin/update_db.pl line 228
at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 673
do_update_db failed with 65280
make[1]: *** [updatedb] Fehler 1
MVP Guru
Re: Airwave auf Centos 6.10
It's no longer possible to get your own OS and install Airwave on top of it. Options are:
- Hardware appliance (pre-installed)
- VM (OVA recommended, ISO possible)
- Your own hardware (ISO).
From the Server sizing guide on 'your own hardware':
To ensure hardware capability, purchase server hardware that is certified to be compatible with Red Hat Enterprise Linux 6.2.
What you can do is check with your local Aruba SE or Aruba TAC if your RAID controller can be supported, which possibly will require to raise an RFE (Innovation Zone). Another option would be to run ESXi (or HyperV, KVM) on your hardware as a middle-layer and run Airwave as a VM on top of that.
