Deutschsprachiges Forum
Highlighted
Occasional Contributor I
How to connect a 7205 Controller to MobilityMaster
Dear Airheads,
I installed the MobilityMaster with Version 8.6.0.2.
Now I want to connect my running WLC 7205 to the MobilityMaster.
I couldn't find any documentation or videos shows how to add a running WLC to MM. Everything I found was about adding a new WLC through Initial Setup Wizard.
Via CLI both devices can ping each other.
What should I do now?
Thank you very much in advance
Kind regards
Kind regards
Philipp Raabe
Accepted Solutions
Highlighted
MVP Guru
Re: How to connect a 7205 Controller to MobilityMaster
When connecting a controller to a MM it will inherit the configuration of the MM. If you are looking to either retain or merge the configuration of the controller with the MM, this is not possible.
If you follow the below video it will show you how to add a controller to a MM. It is the same process for a virtual or physical controller.
https://www.youtube.com/watch?v=eF_tyrV1vzU
To add the MD to the MM, you can use the following command if past the initial set up wizard.
masterip 192.168.1.x ipsec [IPSEC KEY] interface vlan X
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
View solution in original post
All Replies
Highlighted
MVP Guru
Highlighted
This Information is what I am looking for, thank you so much!
Then I will factory-reset the controller and add it via inital configuration wizard like the video explained.
Thank you for your fast reply.
Kind regards
Kind regards
Philipp Raabe
