Developer Community
Highlighted
Occasional Contributor I
Issue with “arubaos_switch_ssh_cli” module
This module seems working with only some show commands(such as ‘show version” and “show flash” ) but not all. Here is an example that does not work.
Aruba-3810M-24G-PoEP-1-slot# show cdp
Global CDP information
  Enable CDP [Yes] : Yes
  CDP mode [rxonly] : pre-standard-voice
  CDP Hold Time [180] : 180
  CDP Transmit Interval [60] : 60
  Port   CDP      Admin status
  1      enabled  tx_rx
  2      enabled  rxonly
  3      enabled  rxonly
  4      enabled  rxonly
I was trying to use below task to get the same information as above:
    - name: show cdp
      arubaos_switch_ssh_cli:
        ip: xxxxxx
        user: xxxx
        password: xxxx
        timeout: 180
        command_list:  [ "show cdp" ]
      register: cdp_result
However, the result returned is cli_output": []
Accepted Solutions
Highlighted
Re: Issue with “arubaos_switch_ssh_cli” module
Hmm.. I've tested both commands on a 3810 running KB.16.07.0002 and both seem to work... Is it that you're receving nothing in the variable? Could you try the following and post the results?
    - name: show cdp
        ip: XXXXX
        user: XXXXX
        password: XXXXX
        show_command: ["no page", "show cdp"]
    - debug:
        var: cdp_result
Here's my solution that's working along with the output:
- hosts: all
  gather_facts: False
  tasks:
    - name: show cdp
        ip: "{{ansible_host}}"
        user: "{{ansible_user}}"
        password: "{{ansible_password}}"
    - debug:
        var: cdp_result.cli_output[1]
    - name: show cdp traffic
        show_command: ["show cdp traffic"]
      register: cdp_traffic_result
    - debug:
        var: cdp_traffic_result.cli_output[0]
OUTPUT
PLAY [all] *********************************************************************
TASK [show cdp] ****************************************************************
[DEPRECATION WARNING]: Distribution Ubuntu 16.04 on host switch1 should use
/usr/bin/python3, but is using /usr/bin/python for backward compatibility with
prior Ansible releases. A future Ansible release will default to using the
discovered platform python for this host. See https://docs.ansible.com/ansible/
2.8/reference_appendices/interpreter_discovery.html for more information. This
feature will be removed in version 2.12. Deprecation warnings can be disabled
by setting deprecation_warnings=False in ansible.cfg.
ok: [switch1]
TASK [debug] *******************************************************************
ok: [switch1] => {
    "cdp_result.cli_output[1]": "\n Global CDP information\n\n  Enable CDP [Yes] : Yes                           \n  CDP mode [rxonly] : rxonly              \n\n\n  Port   CDP     \n  ------ --------\n  1      enabled \n  2      enabled \n  3      enabled \n  4      enabled \n  5      enabled \n  6      enabled \n  7      enabled \n  8      enabled \n  9      enabled \n  10     enabled \n  11     enabled \n  12     enabled \n  13     enabled \n  14     enabled \n  15     enabled \n  16     enabled \n  17     enabled \n  18     enabled \n  19     enabled \n  20     enabled \n  21     enabled \n  22     enabled \n  23     enabled \n  24     enabled \n  A1     enabled \n  A2     enabled \n  A3     enabled \n  A4     enabled \n \n"
TASK [show cdp traffic] ********************************************************
ok: [switch1]
ok: [switch1] => {
    "cdp_traffic_result.cli_output[0]": "\n CDP frame Statistics:\n\n  Port     Transmitted  Received    Discarded   Error   \n  No.      Frames       Frames      Frames      Frames  \n  -------- ------------ ----------- ----------- --------\n "
PLAY RECAP *********************************************************************
View solution in original post
Highlighted
@tiffany got it, thanks!
All Replies
Highlighted
I haven't seen this myself but I spotted that the output of "show cdp" contains the [ symbol. Could the code be intollerent to this special character?
If you have other commands that don't work, do they contain this or other escape characters?
Does " show cdp traffic " produce an error (no [ character on my switches although we don't use CDP).
Ian.
Ian Nightingale - University of York, UK
Highlighted
MVP Guru Elite
It is not always a good idea to try to launch a cli command
it will be better to launch API call
there is a /rest/vX/cdp for CDP configuration
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Thanks for your reply, Ian!
I just tried and it does not look like caused by escape character, since "show cdp traffic" does not work either. See below:
---- Aruba output ---
Aruba-3810M-24G-PoEP-1-slot# show cdp traffic
24 0 46448 0 0
24 0 46448 0 0
------- Ansible output ----
changed: [localhost] => {
"changed": true,
"cli_output": [],
"invocation": {
"module_args": {
"allow_agent": false,
"boot_image": "primary",
"command_list": [
"show cdp traffic"
"enable_sftp": false,
"ip": "xxxxxxxx",
"key_filename": null,
"look_for_keys": false,
"password": "VALUE_SPECIFIED_IN_NO_LOG_PARAMETER",
"path_to_swi": null,
"port": 22,
"show_command": null,
"state": "upgrade",
"timeout": 180,
"user": "admin"
"message": ""
Highlighted
@alagoutte, thanks for your reply and I agree REST is better.
however using REST does require enable it on the Aruba switch.  We try not to make configuration change on the switch unless it is absolutely necessary. If CLI module works as expected, we would prefer to stick to it at this time.
Highlighted
Hi!!
The parameter should actually be "show_command_list" instead of "command_list", that should give you the result back. Could you try and let me know the result?
    - name: show cdp
        ip: xxxxxx
        user: xxxx
        password: xxxx
        timeout: 180
        show_command:  [ "show cdp" ]
Highlighted
@Tiffany, thanks for you reply.
I actually tried both and none of them are working for “show cdp”, using “show_command” would be no response until timeout, while using “command_list” would just return nothing.
I tried a few show command so far, looks like only “show version” and “show flask” work.
Highlighted
Hmm okay so show version and show flash work but not that particular command, do you have paging enabled? It could be since that command runs over multiple pages the module isn’t matching on the prompt. Are you able to disable paging with “no page” before the command?
Highlighted
@jxia I think this is the solution... let me know if this works or not:
    - name: show cdp
        ip: xxxxx
        user: xxxxx
        password: xxxxx
    - debug:
Highlighted
hmmm...I'm not sure it is caused by "paging", the output from "show cdp traffic" is pretty small and it does not work either :(
24 0 46448 0 0
24 0 46448 0 0
