Foro en Español
Sistema Operativo Switches Aruba OS / Comware
Hola Compañeros
Requiero la ayuda de ustedes para confirmar en que esta basado el kernel del sistema operativo de los switches de Aruba/Flexnetworks, si es bajo Unix, Linux o FreeBSD.
Muchas Gracias
+David C.
MVP Expert
Re: Sistema Operativo Switches Aruba OS / Comware
AFAIK Comware is a Network OS based on a streamlined Linux kernel which is used on old/actual H3C, old 3Com/HP and also on actual HPE switching series; ArubaOS-Switch instead is (as HP ProVision was before it) an embedded Network OS running on customzied ProVision ASIC based Hardware (ProCurve switches, now Aruba).
