Foro en Español
problema para asignar vlan y conexion
Saludos
no se mucho sobre este tema de configuracion, tengos 2 AP uno como master en los cuales estan configuradas 3 redes wifi el AP master trabaja correctamente asigna las Vlan y coneciones correctamente , pero el otro equipo solo trabaja correctamente la primera wifi que se configuro, las otras 2 no conectan y no les asigna ip de la Vlan correspondiente , les comparto la configuracion
version 6.4.2.0-4.1.1
virtual-controller-country MX
virtual-controller-key 5952bbc901002bf3141f909d7b817d37be596f580042601814
name instant-C2:20:DC
terminal-access
telnet-server
clock timezone Mexico-City -06 00
clock summer-time CDT recurring first sunday april 02:00 last sunday october 02:00
rf-band all
allow-new-aps
allowed-ap 34:fc:b9:c2:20:dc
allowed-ap 34:fc:b9:c2:20:ba
arm
wide-bands 5ghz
80mhz-support
min-tx-power 18
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode fair-access
client-aware
scanning
client-match
client-match calc-threshold 2
rf dot11g-radio-profile
interference-immunity 3
rf dot11a-radio-profile
ip dhcp pool
subnet-mask 255.255.255.0
dns-server 172.17.63.251
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
mgmt-user admin 97bd1035cb7e5e093bcc74afb98e2770
wlan access-rule SITMEX-MOBILE-N
utf8
index 0
vlan 19
rule any any match any any any permit
wlan access-rule default_wired_port_profile
index 1
wlan access-rule wired-instant
index 2
rule masterip 0.0.0.0 match tcp 80 80 permit
rule masterip 0.0.0.0 match tcp 4343 4343 permit
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule SITMEX-GUEST-N
index 3
wlan access-rule SITMEX-COORP-N
utf8
index 4
wlan ssid-profile SITMEX-MOBILE-N
enable
work-without-uplink
index 0
type employee
essid SITMEX-MOBILE-N
utf8
wpa-passphrase f90c99f7a1f166119471093d6e369ee707ad8cccad3e6d11
opmode wpa2-psk-aes
max-authentication-failures 0
vlan 19
auth-server InternalServer
rf-band all
captive-portal disable
dtim-period 3
inactivity-timeout 1000
broadcast-filter all
multicast-rate-optimization
dynamic-multicast-optimization
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
wlan ssid-profile SITMEX-GUEST-N
enable
index 1
type employee
essid SITMEX-GUEST-N
wpa-passphrase 7dd3f163f79063723d371cc8aa8afcafa3fb491a9aa9cec7
opmode wpa2-psk-aes
vlan 18
rf-band all
dtim-period 1
broadcast-filter arp
wlan ssid-profile SITMEX-COORP-N
enable
index 2
type employee
essid SITMEX-COORP-N
utf8
wpa-passphrase 52fb791d8815065f3525790c6fae170fd4ca25a93badadca
opmode wpa2-psk-aes
rf-band all
dtim-period 3
auth-survivability cache-time-out 24
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
wired-port-profile wired-instant
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-instant
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
enet0-port-profile default_wired_port_profile
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
enable dlna-only
airgroupservice airplay
disable
description AirPlay
airgroupservice airprint
disable
description AirPrint
airgroupservice allowall
enable
MVP Expert
Re: problema para asignar vlan y conexion
¿Tienes extendidas las VLANs entre los dos IAPs? Es decir, si en el segundo AP no se asigna el usuario a dicha VLAN es que no está extendida allí a nivel del switch donde está conectado ese AP.
Rafael del Cerro Flores
ACMP, ACCP, ACDX#324, ACCX#711
