Forum Français
Highlighted
MVP Guru Elite
Re: Problème déploiement OVF Clearpass
@jeremy.e wrote:
Hi all,
Finally, regarding the 2 NICs, I put them in the same subnet and I'm actually only using the management interface. It's not a clean deployment but I had to fit customer's limitations.
Thanks all for your help.
Jérémy
You don't get error when set ip address on the same subnet for 2 interfaces ? (when you setup ClearPass, data interface is not mandatory)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Occasional Contributor I
You're right, my mistake, I did not configure the Data management interface because I had been prompted with same subnet alert.
Thanks for correcting :).
Jérémy
