Internet of Things (IoT) and Industrial IoT (IIoT)
Highlighted
Are Aruba APs able to connect IoT devices?
With radios for Wi-Fi 6 (802.11ax), Bluetooth, and 802.15.4 to support standards like Zigbee, Aruba APs are ideal for connecting a wide range of IoT devices.  They also include a USB port to connect external sensors and additional radios directly into the infrastructure.
For more information:
https://www.arubanetworks.com/assets/so/SO_Access-Points-as-IoT-Platforms.pdf
Highlighted
Re: Are Aruba APs able to connect IoT devices?
EnOcean is one of the IoT device suppliers that is supported in the APs.   800 or 900 MHz so it doesn't bother the 2.4 or 5 GHz channels.    details: www.enocean.com/aruba
