This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
How to connect controller Os 8.3 to ALE
Hi Everyone,
Am using controller aruba 7005 Os 8.3 but can not find folder connect to analytics and Location Engine (ALE).
Can you help me check?
Thank you.
Highlighted
MVP Expert
Re: How to connect controller Os 8.3 to ALE
https://www.arubanetworks.com/techdocs/ArubaOS_83x_Web_Help/Content/PDFs/ArubaOS%208.3.0.x%20CLI%20Reference%20Guide.pdf Check page 151
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
For GUI,
The below Airheads post might be helpful.
https://community.arubanetworks.com/t5/Forum-Fran%C3%A7ais/ALE-amp-AOS8-Notes-d-int%C3%A9gration/td-p/304619
Highlighted
Hi Pavan,
I don't see button ALE? pls check image
Highlighted
Please choose Mobility Master folder (Top folder) and then select More. You will than be able to see ALE option.
Highlighted
Hi Pavan,
Now I creat ssid using captive portal but can't access internet, you can help me check how to add roles from captive portal?
Thank you so much.
Highlighted
MVP Expert
Open new thread this thread is for location query! are you creating roles in Clearpass or controller? If you are getting internet then check ACL rules for that role.
Highlighted
Hi Pavan,
I follow link but config ssh erro , can you help me check?
(attach file)
and Check page 151
Highlighted
Dear Pavan,
My controller: ArubaOS (MODEL: Aruba7005), Version 8.3.0.6. But when config ALE as your guide, it said:
(Aruba7005) [mynode] (config) #ale-configuration
Command not applicable for this platform
How can I fix this? Thank you very much.
Highlighted
MVP Expert
Are you running on MD or its a standalone controller? I am able to run on my MM.
(DK-MM) [mynode] (config) #ale-configuration
(DK-MM) ^[mynode] (config-submode)#
