Highlighted
MVP Expert
Re: Support ALE Location Base Services on IAP
ALE receives data depend on value you configure in IAPs report interval. I see you are looking at command "feed-reader -f location",  ALE will calculate location of the client based on RSSI data it have, if ALE does not have enough RSSI info it will not calculate the location.
You can try enable in ALE if you want ALE to calculate the location even if single IAP hearing that client
Enable Single Ap Location Calculation
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
View solution in original post
