Monitoring, Management & Location Tracking
Airwave does not import IP-Sec key from the local controller, shows as configuration mismatch
MVP
MVP
Q:
I have Master and Local controllers in different group in Airwave, Master's configuration shows good. However, unable to import, local controllers IPSEC Key in the local controller's group. it ends up showing as a configuration mismatch, as shown below:
A:
IPsec keys would not be imported from the local controller, even if the local controller is placed in different group, we have two ways to address this issue:
1. We could ignore this mismatch, by clicking on Customize shown in the above screen shot and select this line to ignore it.
2. Move, Master and local to same group.
Version history
Revision #:
2 of 2
Last update:
‎06-07-2019 07:27 PM
Updated by:
Labels (1)
Contributors
