- Article History
- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Email to a Friend
- Printer Friendly Page
- Alert a Moderator
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Cisco Switch Is Not Populating Connected Device Table When We Use SNMP Version 3
Below, we can see the Connected devices table empty for Cisco Switch on Airwave when using snmpv3
Diagnostics:
This will work when we are using snmpv2.
In the PCAP below, we can see the error "error-status:authorizationError (16)" in the get-response.
Solution
We can add the below configuration to the Cisco switch to get this issue addressed.
******Log in to switch *******
# configure terminal
Cisco3850Switch(config)# snmp-server view WD_SNMPv3 iso included
---- the above command is creating WD_SNMPv3 view
Cisco3850Switch(config)# snmp-server group WD_SNMPv3_Group v3 priv context vlan- match prefix read v1default
---- the above command : 'v1default' is a default view
Cisco3850Switch(config)#snmp-server group WD_SNMPv3_Group v3 priv read WD_SNMPv3
---- the above command, 'WD_SNMPv3' is manually created view
# exit
#write memory
Cisco3850Switch# show run | include snmp
Cisco3850Switch# show snmp view
WD_SNMPv3 iso - included nonvolatile active
v1default iso - included permanent active
v1default internet - included permanent active
v1default snmpUsmMIB - excluded permanent active
v1default snmpVacmMIB - excluded permanent active
v1default snmpCommunityMIB - excluded permanent active
v1default ciscoMgmt.252 - excluded permanent active
Cisco3850Switch# show snmp group
groupname: WD_SNMPv3_Group security model:v3 priv
contextname: <no context specified> storage-type: nonvolatile
readview : WD_SNMPv3 writeview: <no writeview specified>
notifyview: <no notifyview specified>
row status: active
contextname: vlan- storage-type: nonvolatile
readview : v1default writeview: <no writeview specified>
row status: active
***** Create user "WD_SNMPv3_SHAAES128" with sha1 and aes
***** We created user from UI and assign group "WD_SNMPv3_Group" to that user
