Q:
Few Clients missing in ALE though they are present in Airwave and contorller
(024-ARMC-01) #show user-table mac 70:1C:E7:14:7B:C0
Users
IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name
10.24.36.151 70:1c:e7:14:7b:c0 boan2908 AFK-laerer 00:02:12 802.1x 024-IKT-AP01 Wireless Akershus-FK/18:64:72:19:6e:32/a-VHT Akershus-FK-aaa_prof tunnel Win 10
can see the access point the client is connected to is active on that controller.
(024-ARMC-01) #show ap active
Active AP Table
Name Group IP Address 11g Clients 11g Ch/EIRP/MaxEIRP 11a Clients 11a Ch/EIRP/MaxEIRP AP Type Flags Uptime Outer IP
024-IKT-AP01 024-Vestby 10.24.36.34 0 AP:HT:11/12.0/18.5 3 AP:VHT:36E/23.0/23.0 225 Ada 23d:15h:5m:40s N/A
A: Check whether ALE is calculating the location of the missing client. We need to tail the location log to see whether location is getting calculated for that specific client or not. If location itself is not getting calculated then issue might be due to RSSI value, need to check on deployment side.
#tail –f /opt/ale/ale-location/logs/ale-location.log | grep 701ce7147bc0
2017-11-10 09:37:19.494 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:37:49.627 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:38:30.062 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:38:59.929 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:39:19.335 CET [pool-1-thread-2] DEBUG c.a.a.l.records.StationRecord - TARGET_TYPE_STATION 701ce7147bc0 scheduled with 2 RSSIs:[RssiRecord [rssi=-49, tsSecs=1510303027, bssid=24dec6fa0870, channel=0, classificationType=-1], RssiRecord [rssi=-49, tsSecs=1510303028, bssid=24dec6fa0870, channel=0, classificationType=-1]]
2017-11-10 09:39:19.821 CET [engine-worker-4] DEBUG c.a.a.l.records.StationRecord - New location for TARGET_TYPE_STATION 701ce7147bc0: x=31.966356, y=8.974388, floor=995A5F24F45C3A22AB9921BC38592CA7, algo=ALGORITHM_LOW_DENSITY
2017-11-10 09:39:29.914 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:40:00.096 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:40:30.227 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:41:00.366 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:41:30.579 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:42:00.701 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:42:30.860 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:43:11.087 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:43:30.256 CET [pool-1-thread-2] DEBUG c.a.a.l.records.StationRecord - TARGET_TYPE_STATION 701ce7147bc0 scheduled with 2 RSSIs:[RssiRecord [rssi=-51, tsSecs=1510303329, bssid=24dec6fa0870, channel=0, classificationType=-1], RssiRecord [rssi=-51, tsSecs=1510303258, bssid=24dec6fa0870, channel=0, classificationType=-1]]
2017-11-10 09:43:30.470 CET [engine-worker-4] DEBUG c.a.a.l.records.StationRecord - New location for TARGET_TYPE_STATION 701ce7147bc0: x=10.036356, y=9.970388, floor=995A5F24F45C3A22AB9921BC38592CA7
In above logs, we see client location is getting calculated by a unknown BSSID, We see such log entrees, if AP details missing in airwave or visualrf. Check whether this particular AP which is reporting this station is added to Airwave and also provisioned in VisualRF. ALE get AP location from VisualRF.
#ALE
