Glass Server Web Interface Is Not Accessible
MVP
MVP
Problem:
Glass Web interface down and not accessible
Diagnostics:
We are able to SSH to Glass Server.
When we check the status of pods using the below command, we received the below message
admin@aw-glass~ $ kubectl get pods --all-namespaces
The connection to the server 127.0.0.1:8080 was refused - did you specify the right host or port
We can run the below command to verify the status of kubelet service, per the below output, kubelet service is running
admin@aw-glass~ $ sudo systemctl status kubelet
? kubelet.service
   Loaded: loaded (/etc/systemd/system/kubelet.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2019-06-12 16:11:13 UTC; 1 months 2 days ago
 Main PID: 3366 (kubelet)
    Tasks: 21124
   Memory: 762.9M
      CPU: 6d 11h 55min 36.708s
Checked the status of docker process status using the below command.
aadmin@aw-glass~ $ docker ps
This command did not list any container ID or images and the command was stuck and returning no output.
Solution
Restarted docker using the below command.
admin@aw-glass~ $ sudo systemctl restart docker
After restarting docker we are able to see the container ID and images got listed for "docker ps" command.
Also, we are able to access the web interface of Glass Server.
Version history
Revision #:
1 of 1
Last update:
‎10-30-2019 05:48 PM
Updated by:
