Monitoring, Management & Location Tracking
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
How to disable root access on Airwave versions prior to 8.2.4
MVP
MVP
How to disable root access on Airwave versions prior to 8.2.4 for Security reasons and to be able to track the user activity.
Note: This is not applicable for the Airwave versions 8.2.4 and above as the root access is by default blocked going forward.
We will need to make sure, we create the sudo root user first, before disabling the root user.
  1. Please make sure to create a user account with Sudo root access, by doing the following:
useradd awsupport   (awsupport is an example you could create any user name)
passwd awsupport
will prompt for the new password and then the confirmation. Giving the user sudo privileges requires adding an entry to the /etc/sudoers file. You can do so by running
/usr/sbin/visudo
and then adding one of the below lines, the 1st will prompt for password, the 2nd will not:
## Allows people in group wheel to run all commands
awsupport ALL=(ALL) ALL
## Same thing without a password
awsupport ALL=(ALL) NOPASSWD: ALL
Once this is done, please login to the CLI using the above credentials, and make sure you are able to run # sudo sh and get into shell mode.
    2. Steps to disable the root access:
[root@root ~]# vi /etc/ssh/sshd_config
Change this line:
#PermitRootLogin yes
Edit to this:
PermitRootLogin no
Ensure that you are logged into the box with another shell before restarting sshd to avoid locking yourself out of the server.
[root@root ~]# /etc/init.d/sshd restart
Stopping sshd: [ OK ]
Starting sshd: [ OK ]
[root@root ~]#
Now we could try ssh using putty or any other tool, using root as the username and we could see the below error:
login as: root
root@<ip or hostname> password:
Access denied
However, if you are logged with other user, should be able to login as shown below:
login as: testing
testing@10.17.164.249's password:
Last login: Thu Jun 22 10:15:06 2017 from 10.20.25.25
[testing@localhost ~]$ sudo sh
sh-4.1#
Version history
Revision #:
2 of 2
Last update:
‎06-07-2019 07:15 PM
Updated by:
Labels (1)
Contributors
