Q:
How to fetch IAP certificates details using Airwave API?
We have batch execute API command option to fetch details from IAPs.
API Syntax:
Batch execute command API
https:// <server ip>/api/batch_command_execute
Batch execute command Result
https://<server ip>/api/batch_command_execute_result
API parameters which we can use in query.
cmds- We can provide list of commands separated by comma.
cmds_type (OPTIONAL)- We can use "thin_ap" for IAPs and for other types ignore this option.
Example:
https://10.27.144.xx/api/batch_command_execute?cmds=show cert all &cmd_type=thin_ap
https://10.27.144.xxx/api/batch_command_execute_result
