How to reset webUi password of ALE?
MVP Expert
MVP Expert
Problem:
How to reset webUi password of ALE version 1.x?
Diagnostics:
If you forgot the password and would like to reset it, it is very simple that you can reset with your new password from the command line interface of ALE.
Solution
Login to ALE command line interface and run the following command to reset UI admin account's password to admin123.
[root@ale ~]# /opt/ale/bin/htpasswd.py -­‐b /opt/ale/html/.htpasswd admin admin123
[Note: This will not work on ALE version 2.x]
Version history
Revision #:
1 of 1
Last update:
‎06-07-2019 03:02 PM
Updated by:
