Monitoring, Management & Location Tracking
VisualRF and IAP loss communication after installing custom certificate in Airwave
MVP
MVP
Problem:
VisualRF engine and all IAP devices in Airwave showing status as down after installing custom certificate
Diagnostics:
VisualRF log
javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: Certificates does not conform to algorithm constraints
    at sun.security.ssl.Alerts.getSSLException(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
    at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
    at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source)
    at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source)
    at sun.security.ssl.Handshaker.processLoop(Unknown Source)
    at sun.security.ssl.Handshaker.process_record(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
      at com.airwave.core.AbstractService.run(AbstractService.java:474)
    at java.lang.Thread.run(Unknown Source)
2018-06-15 15:47:19,597 ERROR Inventory    com.airwave.svg.AmpInventoryServiceImpl Service [Inventory] is shutting down due to the error[java.security.cert.CertificateException: Certificates does not conform to algorithm constraints]
2018-06-15 15:47:19,597 ERROR Inventory    com.airwave.svg.AmpInventoryServiceImpl run
Signed certificate details
Solution
We see javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: Certificates does not conform to algorithm constraints messages if we are using Signature algorithm SHA1withRSA WEAK
In VisualRF Java file SHA1 is not supported and same file is used for instant too, due to this both went down after installing certificate.
To fix, we need to sign generated CSR using algorithm SHA2 and higher.
Version history
Revision #:
2 of 2
Last update:
‎06-08-2019 01:20 AM
Updated by:
Labels (1)
Contributors
