Monitoring, Management & Location Tracking
Why I am not able to see client usage graph in device (Aruba mobility controller) monitoring page?
MVP
MVP
Problem:
Why I am not able to see client usage graph in Device (Aruba mobility controller's) monitoring page?
Diagnostics:
If the client usage graph in the device monitoring page is not loading in AirWave, please check whether the BSSID tunnel stats is enabled in Aruba controller-AMON profile.
Solution
For AirWave to receive the client usage info, we must enable BSSID tunnel stats in controller.
Login to the Aruba controller’s CLI and check whether the BSSID tunnel stats is enabled, if not enable by following the below commands:
After enabling the BSSID tunnel stats we must start seeing the client usage graph in the Aruba controller's monitoring page.
Version history
Revision #:
2 of 2
Last update:
‎06-15-2020 01:00 AM
Updated by:
Labels (2)
Contributors
