Network Management
Highlighted
Contributor I
AMOP 8.2.7: Restore with Nightly backup?
I know we can download nightly backup now via Webgui in 8.2.7.. but how can we restore AMP with a downloaden nightly backup?
I think using Webgui as well, but can not find it.
Highlighted
MVP Expert
Re: AMOP 8.2.7: Restore with Nightly backup?
We need to upload the backup file  using scp option and execute restore from AMPCLI command list.
If you are not able to upload the file then you need to take the help of TAC they will assist in upload the backup to the server.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Contributor I
Alright, that makes sense, but I know SCP is unavailable - correct by default? Or is there a manual how to set it up in 8.2.7?
Highlighted
MVP Expert
AirWave Management Platform 8.2.7 on localhost.localdomain
  1  Upload File
  2  Download File
  3  Delete File
  4  Backup
  5  Restore
  6  Support
  7  Upgrade
  8  Advanced
  9  Security
10  Custom Commands
  q  >> Quit
Your choice: 1
Running Upload File
SCP Source (user@host:path): root@10.17.164.XX:/tmp/AMP-8.2.7-X86.64.cvs.tar.gz
Password:
Uploading root@10.17.164.XX:/tmp/AMP-8.2.7-X86.64.cvs.tar.gz
        100%   10KB  10.0KB/s   00:00
You need exteranl server to upload file.
