Network Management
Highlighted
Contributor I
Re: AMP Device Events retention in AirWave 8.2.7
Phew... Good to know that was a bug, not a feature :-) I'll see about contacting TAC to try to find out why and run those log commands for me.
Back to the device event history - have you noted that as a feature request, or do you want me to formally request it somewhere?
Highlighted
Contributor I
Update: I got diagnostics tarball to generate via cli, and it contains complete event, audit, config and command logs for every single device. Seeing as each device page already uses the per-device audit log, it seems logical that it should do the same for events. At least the information is readily available, unhindered by any limits on the central event log.
Highlighted
Moderator
it's best if you can submit the request.  innovate.arubanetworks.com is the portal address.  if you can't access, let me know and i can try - it just looks better when PLM sees that there's an actual customer attached.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
View solution in original post
Highlighted
Contributor I
Thanks, I'll do that :-)
Highlighted
Contributor I
