Network Management
Highlighted
Adding a Wired Switch (not a AP) to a Floor Plan
Hi Everyone
I am looking for a solution of how to show not only our AP's on floorplans, but also the location of our Aruba 2530 switches (8/24/48 port)
The idea is that we can see on one plan the locations of these switches in the remote comm cabinets, alongside the AP data and heat maps.
Its really for point of reference rather than needing any active data.
Cheers
Craig
Accepted Solutions
Highlighted
MVP Expert
Re: Adding a Wired Switch (not a AP) to a Floor Plan
Currently we do not have this feature , please file one at
innovate.arubanetworks.com/
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
View solution in original post
All Replies
Highlighted
This would be a useful feature. Also it would be nice to add items to network topology manually.
Highlighted
@triggers88 wrote:
Hi Everyone
Cheers
Craig
Are you referring to the "wiring closet" feature in Airwave?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
Thanks cjoseph
But I am not looking for a wiring closet layout.
I'm looking to add Wired switches to a floorplan, in the same way you can add wireless access ports....
Highlighted
MVP Expert
