Network Management
Highlighted
AirWave 8.2.9 OVA extend Hard Disk
Any method to extend the AirWave 8.2.9 OVA HD? the default size is 80G only, thanks a lot.
Highlighted
MVP Expert
Re: AirWave 8.2.9 OVA extend Hard Disk
We need root access to extend partition and only TAC have access to it. Open TAC ticket before that allocate more disk space by power off Airwave instance and once done poweron.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Moderator
Was this a fresh install?  Ideally, OVA is used for POC and small installs.  It's far quicker to use the ISO when doing fresh installs since that would allow for customizing the resources.  The OVA saves about 20 min since it is generated after OS install; but after opening TAC, resizing, reloading - that 20 min saved may be a moot point.
I generally install from the ISO whenever I can.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
