Network Management
Contributor II
Re: AirWave Restore From Backup
Nightly backup on AirWave starts at 4:15 AM daily (unless changed) and finishes based on the data to be claned and backed up. If the jobs are deleted on the AirWave server post the backup is created, the recent backup will have these jobs. If a nightly backup ran after the deletion of jobs, then the backup will not have the jobs. There is no option to just backup the jobs created on the AirWave.
IMHO F/w upgrade jobs are very small in size so it doesnt increase the backup size size a lot. There should be other historical data thats causing the backup to be 10G.
