Network Management
AirWave Topology
I have an issue with AirWave where by the I cannot get the Topology pages to load at all. After navigating to Home > Tolopgy the AMP gets stuck on a grey screen with a loading bar in the centre (see attached).
I am running H/W appliances with AirWave 8.2.7.1.
I have logged in as both admin and RO user.
The server in question has approx 1250 devices on (Aruba 325 WAPs, 7210 WLCs and 3810 switches)
Has anyone else had this issue?
Thanks!
MVP Guru
Re: AirWave Topology
It is known issue and most of toplogy related issue will going to be addressed in next release 8.2.8 and it will be out in couple of days. Upgrade the server and check the status.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
MVP Expert
We have 8.2.8 released now and various page load issues for Topology is addressed on the same. Could you try to upgrade to latest code and check the status? I have attached the release note for the same for your reference.
Vishnu
If my post helped you, don't forget to give kudos ;)
