Network Management
Highlighted
AirWave VM Sizing
Hello, good day everyone.
I've been searching in the web for al Aruba AirWave sizing depending on the quantity of APs it will manage and I can't find anything. Can anyone help me to size the VM requierements?
I will install from 18-25 Aruba 345 APs, they can't be Instant because I need to make AP groups for broadcasting different SSIDs in different AP groups.
How can I dimensionate the VM? And another question, does the VM has to be in the same L2 network than the APs? Or can it be in another network that can see the APs network?
Thanks.
Highlighted
Re: AirWave VM Sizing
There is a sizing guide here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=32996
The difference between a VM and regular Server hardware is this:  "Aruba recommends a 20% increase buffer for virtual environments. Ensure you allocate enough extra disk space for the OS and swap when partitioning the virtual disk."
- Instant APs can use Zones, to decide what SSIDs are broadcast on which APS.
- The VM does NOT have to be on the same layer 2 network as the APs or controller.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
Highlighted
Looking at your small number of APs, you can honestly get away with 4 CPU, 8 gigs of RAM and 100 gigs of space on a VM.
Highlighted
Thanks for the info cjoseph.
About Instant Zones, where can I find it and configure the APs en each zone?
Thanks.
Highlighted
Highlighted
MVP Expert
8GB RAM and 4 CPU cores are for HW appliance, irrespective on number of device monitoring, we still recommand 20% more resource allocation if server is installed on VM.
We will see system performance issue with 8GB RAM and 4 cores CPU on VM even with this  AP count.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
