Network Management
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
MVP Expert
AirWave installation with problems
Hi guys,
I have downloaded the .iso of AirWave 8.2.8.1 and made a booteable USB. I have restarted my sever from the USB drive and gone through the installer wizard, and I supposed this will install AirWave automatically. At the end, when the wizard ask you to restart the machine, it seems to restart OK, the CentOS loads, shows the logo and finally the prompt appears to enter the root user and password. After entering, the prompt keeps appearing, no menu appears to set the time, the AMP IP address, and so on. If I type "install" the prompt doesn't recognize the command. I am stuck there, what's the next step? What shall I do? Many thanks in advance.
Julián
Highlighted
Re: AirWave installation with problems
I believe you have to type:
EDIT:  Incorrect ./install
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
MVP Expert
After login with root/admin credetnails, type ./amp-install command to install airwave
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
MVP Expert
Hi guys,
No luck :(
Any tip?
Julián
Highlighted
MVP Expert
Try this command
[root@localhost /]# root
[root@localhost mercury]# cd install/
[root@localhost install]# ./amp-install
Highlighted
MVP Expert
When I type "cd install/" the promt says "No such file or directory", it seems that directory is not installed, but I don't know why.
Julián
Highlighted
MVP Expert
If I type "dir", I can see there are only three files: "anaconda-ks.cfg", "install.log" and "install.log.syslog", there are not directories. In the bootable USB I made there is a file named "install.img", within the directory "images". I am thinking to install AirWave as VM with the file .ova, but I wonder if I can rescue this installation before going with the VM option.
Julián
Highlighted
Moderator
I don't think this current installation will work or be saved.  From your description, the folder tree is missing several elements.  What application did you use to generate for USB boot?  I'd like to attempt the same in-house.
If the OS portion of the install succeeded as expected, then the login w/ root after reboot should auto start the amp-install script which should be in /root on a fresh installed system.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Highlighted
MVP Expert
Hi Rob,
I agree with you, I remember some time ago I installed AirWave from a ISO DVD with no problems, and the whole process was automatic. This time I use Rufus 3.4 for making the USB bootable device:
And the USB ends like this:
I attached my installation process, at the beggining I have an error, it seems the CentOS doesn't recognize the USB device:
After clicking on Cancel:
And finally, after rebooting the system:
Any idea? Thanks very much for your help.
Julián
Highlighted
Moderator
Thanks, I'll update when I get a chance to test with Rufus.
Rob Gin
