Network Management
Frequent Contributor II
AirWave switch port monitoring
Hi Guys,
Just wanted to ask if it is possible to monitor individual switch ports within AirWave and create alerts if the ports go down?
In particular configuring this with 2930F, 3810, and 5400 HPe switches.
Also if you could confirm if this can be done with any other switch vendors.
MVP Guru
Re: AirWave switch port monitoring
If you recieve a SNMP trap from the switch in question when the port is down, you can trigger an alert on AirWave to inform you of this trap.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Thanks for the confirmation that it can done.
Now how do you configure this from AirWave side, I have seen the following traiggers within AirWave:
- Device Uplink status
- Interface Usage
- Interface errors
How would you configure the alert in AirWave to act on the trap?
I cannot see which catogory this would fit into on the trigger section, am i looking into the right section or should this be configured another way.
MVP Guru
in the first instance you need to find the exact trap generated by your switch when the event occurs. Then base a trigger on Device Event with either Event Contents or Event Type using the generate trap.
Thank you that is very helpful.
