Network Management
AirWave virtual machine ACPI shutdown
I was wondering why AirWave is not reacting to the ACPI Power button gracefully shutdown signal. Since I'm running the Appliance as a VM, the host must be able to shut the VM down before he shuts down. Else he will just stop the machine after a timout, since in he worst case the UPS won't last forever. I know how to shut the VM down via CLI, but that's stupid.
MVP Guru
Re: AirWave virtual machine ACPI shutdown
We didnt come across any such issue, may be server is busy during the time when you are initiating power off or issue with your VM host.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
