Network Management
Highlighted
Airwave 8.2.10.0 upgrade centos 6 to 7
Goodday all,
Just updated from 8.2.8 tot 8.2.10.0.
Everything went well, but not the centos.
Can somebody tell how to do this?
In the release note you have build a new one. Is that true?
Thank you in advance!
Accepted Solutions
Highlighted
ryh
Contributor II
Re: Airwave 8.2.10.0 upgrade centos 6 to 7
Yes- while there is a "Upgrade OS" within the CLI menus it only upgrades to the latest minor version (6.9 or 6.10), not the major version.  To obtain a new "CentOS 7" version you have to build it again - the OVA file contains the new version if used to build a new instance.  A hardware AW upgrade would be similar in process but we would have to build it from scratch (install the OS first, then use the .iso file for the AW install) on the same box after copying off the backup file.
To upgrade CentOS for Airwave the process in the Release Notes is correct:
  1. First, upgrade your live AW to 8.2.10.0.  This upgrades the databases so they can be restored later in the steps.
  2. Backup this live AW and copy off this backup file somewhere
    1. (CLI) Backup > Backup Now.
      1. (GUI) To grab the "nightly" or "weekly" backups - if you've waited long enough since the upgrade to 8.2.10.0 so they can run since your upgrade - go to System > Backups
    2. Command line for SCP from AW (don't use Solarwinds SFTP/SCP Server as it doesn't like the encryption ciphers... OpenSSH in Linux works well) (This step is the most difficult in terms of getting the SCP server running, reachable, and the syntax correct):
      1. If I had a "awbackupfolder" folder on my Linux box on the Desktop for a user named "username", I would reference the existing folder as relatively from my login directory: Desktop/awbackupfolder/  (the trailing "/" is optional here)
      2. The CLI SCP syntax cannot take the "~" tilde character so reference the folder in another way
      3. username@192.168.21.21:Desktop/awbackupfolder/
    3. Power off the AW server (we'll need the new box to have the same IP because AW licenses are tied to it)
  3. Build a new AW server with the right storage, cpu, and memory requirements.  This is a good opportunity to increase hard disk size if you've been holding off.
    1. Building from OVA file will install the CentOS 7 version.
    2. To login to the newly deployed box, use the default: user = root and password = admin
    3. Use the same basic startup-script info as before, keeping the same IPs
    4. You will need a complex password.  Store it somewhere safe: this is your CLI and your WebUI password for "admin" login
  4. Once the box is up, from the CLI copy over the backup file via SCP.
    1. Files > Upload
      1. username@192.168.21.21:Desktop/awbackupfolder/ampbackup_date_time.tar.gz
  5. Now restore from the backup.
    1. Backup > Restore > AMP Restore, select the file.  Sometimes the numbers don't match what you type - I think due to hidden files (.digest files).  Make sure it is the right one (it should be the only one here)
    2. VisualRF backup file is already contained in the AW Backup file, so there isn't a need to do that restore separately.
  6. Log in to the system after it is up with the new password.  Perform basic checks that information is still flowing correctly.
  7. Delete the old virtual machine once everything is running fine.
  8. Have a cup of coffee.
View solution in original post
All Replies
Highlighted
ryh
Contributor II
    1. Files > Upload
Highlighted
Spoiler
Thank you Ryh,
That went very well!
Goodday!
Highlighted
Occasional Contributor I
for me,this is not really an upgrade path.
Is engineer working for a really upgrade procedure ?
so when you upgrade an existing airwave to the 8.2.10. version, the centos is also upgraded to version 7 .
Highlighted
When we upgrade the exsisting Airwave to 8.2.10 only the application part will be upgraded and not the CentOS part. CentOS will still be 6.9. We need to use the iso/ova and do a fresh install of 8.2.10 to get CentOS 7 installed.
Vishnu
If my post helped you, don't forget to give kudos ;)
Highlighted
ryh
Contributor II
Only by installing it fresh does the CentOS 7 get installed.  The normal upgrade procedure will upgrade AW (aka AMP) but not its underlying OS - it will only update CentOS to version 6.9 or 6.10.
While it is inconvenient, this is a good opportunity to re-scale the VM at this time if you have a need.  I have many customers that are running AW servers that are underscoped now because their deployments grew or applications grew since initial installation, who will now address this.
Highlighted
can i upgrade from 8.2.6 to 8.2.10 using option 7. then do the CentOS 7 refresh at a later date?
Highlighted
You have to go to version 8.2.8.x first then to 8.2.10. You can refer the release note for reference.
Vishnu
Highlighted
Contributor I
What happens if we upgraded to 8.2.10 and kept using CentOS 6.9 or 6.10?
Highlighted
Nothing will happen. However, moving forward all the Airwave version will be released on CentOS 7. Hence, we have to migrate if we have to go to latest releases.
Vishnu
