Network Management
Highlighted
Occasional Contributor I
Airwave 8.2.11.0 - Suppress triggers outside core business hours
Good Morning Airheads,
I didn't know if with the newest version of Airwave out recently (8.2.11.0), it's possible to add a condition to suppress alerting based on time?
It doesn't matter for me if APs drop after hours as no one will be in the building, and I wouldn't resolve it until the next day anyways.  I would still like to know about Controllers regardless of time, so would prefer to modify a trigger as I have separate for APs/Controllers.
Thank you for your time!
Accepted Solutions
Highlighted
MVP Expert
Re: Airwave 8.2.11.0 - Suppress triggers outside core business hours
We can not suppress trigger based on hours, in trigger condition we have option "suppress until acknowledge "  if we set this to YES then first time Airwave will trigger alert but next time if same devices goes down it will not trigger alert until first alert is acknowledge in Airwave.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
View solution in original post
All Replies
Highlighted
MVP Expert
