Network Management
Airwave 8.2.7.1 - How can I view AP configuration backups and/or restore?
Hi all,
I'm new to Aruba and Airwave.
I have added my virtual chassis and APs to Airwave using a variety of groups.
I'm trying to understand how Airwave manages backups of the AP's configurations.
is there a place in AirWave where I can see the config backups and/or restore the config to the AP?
MVP Guru
Re: Airwave 8.2.7.1 - How can I view AP configuration backups and/or restore?
Under config page you see the device configuration if you are using template mode, if instant is enabled the you will see the archeived config in Groups>Instant page
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
what is the difference between "Template mode" and "Instant mode"?
MVP Guru
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=31027
Pavan
